Tap Cons
12K views 41 replies 14 participants last post by  nickko
HI
I fastened a ledger for a deck to concrete block using 3/8 tap cons and the inspector told me that he was just at a seminar that said that Tap Cons should not be used where moisture is present.I ask him if i could use steel expansion anchors and he said i don't know. Then i ask him what i should use that he would approve and he said to ask my local supplier and they would know what i should use. I would think the inspector would know what he would approve as the proper fastener.Does anyone know if 3/8 Tap Cons are suitable for a ledger attached to concrete block.
It seems strange that the inspector could tell me what not to use but cant tell me what he would approve.
thanks...............nicko
#2 ·
Well I just called Tap Con and they told me that the blue Tap Cons are for dry interior use and the gray or stainless steel are approved for wet locations. The wedge anchors are also not to be used for exterior but you can use there stainless steel wedge anchors. the longest ss wedge anchors they make are 3 3/4. They are the Red Head brand that are also made buy the makers of Tap Con.
#22 ·
YES!!!
I love it when people take responsibility and reach out to the actual source for information. Great job. You’re the president of your LLC or Inc. company and you have every right to go speak to the president or CEO of any other company or their representatives to get answers.
That’s definitely ”like a BOSS” move.
Great job.
#3 ·
Whenever I’ve had to hang a ledger off of block, first of all it has to be fully grouted and have a rebar grid, and then I’ve drilled and epoxied 1/2” all-thread.
Not saying it’s the only way to do it, but I would never use a TapCon in that application, and I certainly wouldn’t use one that short. That would not even penetrate into the block core.
#6 ·
#13 ·
The Tapcon[emoji2400] concrete screw with the Climaseal[emoji2400] coating gives excellent rust resistance when used for indoor applications and outdoor applications. Tapcons come in two diameters: 3/16” and 1/4”. The 3/16” Tapcon screw requires a 5/32” hole in the concrete, and the 1/4” Tapcon screw requires a 3/16” hole in the concrete. Each box of 100 screws is packaged with the correctly matched tolerance carbide tipped a concrete bit.
Mike.
___
[emoji631] [emoji631]
#16 ·
For a short spell epoxy in mess tubes with threaded rod was recognized in the DCA deck guide then it was dropped.
I think through bolting is the only way to do it in hollow CMU.
Inspector's are not legally allowed to advise because then they are taking a design responsibility. Legal stuff. They can say they've seen .......this or seen someone do that....
#29 ·
#32 ·
That’s interesting. I just ordered SS wedge anchors but I’m going to show that to the inspector. When I called Tap Con they told me blue were for interior or non wet locations. I guess they don’t know about that picture on there website
nicko
#33 ·
It amazes me that so many reps are not as knowledgeable about their own products as the builder is. It happens a lot actually. Makes sense because we more than likely installed much more than they have.
Mike.
___
#34 ·
I always thought blue color meant exterior coating .That said it is not a great .Treated wood dissolves it .
Love titans .easy to work with .less problems .Wedge anchors are likely to give me trouble .do not grab sometimes or end up pulling out to much when tightened .I have demoed a few just with a big pry bar . Glue and all thred is what i use in all sismic . I use the 5/32 and 3/16 tapcons or such screws for small stuff .Never structual . I find them to be a pain in the a### .strip out ,jamb and break to much .
#40 ·
#42 ·
