Put it on the inside of the house where it belongs.
Build a heated shed around the water heater.I have a client who has a tankless water heater mounted on the exterior. He has had the pipes frozen over the last couple of nights because of the cold. The unit is mounted on the exterior wall and the pipes go in right at the unit into the interior. What can we do to keep them from freezing?
Thanks for your help.
I did not mount it. It is for one of my regular customers. It is like a lot of the ones that I have seen around. It is gas so it is vented. It is designed to be mounted outside. I think they just forgot to how to stop the frozen pipes.What makes you think I am kidding? A water heater in a freezing climate will have problems with the pipes freezing. What is the reason that it is mounted outside?
That won't work with a tankless water heater.Yeah, it does freeze sometimes in NC. I've been there when there was freezing rain, and it ain't a pretty sight.
Probably the simplest quick fix would be heat tapes. Until you can get that set up, just have him let the water trickle (or even just a fast drip) at a HW faucet whenever the temps are low. As long as the water's moving even a little bit, it takes some pretty low temps to freeze it solid.
I was waiting for that! :thumbsup:That won't work with a tankless water heater.
I admit I have no hands-on experience with them, so correct me if I'm wrong (like you wouldn't :laughing. The idea is not to get it to fire up--I know you need significant flow for that. It's just to keep the water moving ever so slightly.
Shirley you aren't saying that a tankless won't allow you to run a trickle, as long as you don't care whether it's heated?
Why do the Bosch ones slow the flow down so much?
I have installed 3 TL water heaters and 2 of the customers made me take them out. They were all bosch.
All you would need to do is have one faucet running to keep water moving through the water heater. This would be no different than a few dripping faucets added up. I've never heard that letting afaucet drip or run alittle with a tankless would foul the flow sensor. What manufacturer's users guide says this?You'll foul up the flow sensor and send poor signals to the control panel, depending on the brand of tankless as to what gets screwed up from there, if it's a Bosch just write it off and start over again.
