Is there anywhere i can find a single pole-3way double rocker switch.
I am assuming that your looking for a duplex (two switches on one yoke) switch to fit in a single gang box. (If I'm misundertanding, feel free to set me straight.)zooter7878 said:Is there anywhere i can find a single pole-3way double rocker switch.
The "double rocker" terminology sorta threw me too, which is why I assumed he was referring to a duplex-style switch. I wouldn't beat him up too bad, given the differences in regional trade slang. Down here a "handy box," a "utility box," and a "Raco 660" are all used to describe the same thing.mdshunk said:I t hought that this forum area was for electricians and such. 'Single pole' and 'three way' describe two different switches, and 'double rocker switch' describes nothing at all. This is not how an electrician would describe such a switch.
PipeGuy said:I resigned myself to imagining that Rhett had properly deciphered the post. I'd say he nailed it.
Teetorbilt said:Want to have some real fun? Go to SW Loosiana and hang with them cajun's for a few weeks.
Reason #1 why you shouldn't be doing this and an actual electrician should.zooter7878 said:... I work for an insurance restoration comp[any].
mdshunk said:Reason #1 why you shouldn't be doing this and an actual electrician should.
This looks like this user is using Babelfish to post. Me not understand.shimmerl said:hey zooter u r right learning is good but teaching must be better right?
