1 - 11 of 11 Posts
I am going to tackle a bedroom suspended ceiling for a client while await some trades to finish up. Whats your trick for cutting wall angle on angled wall intersections for aesthetics. Is it a overlap and angle the bottom piece or? Whats your trick for the 90's in the corner overlap or 45. They are using 2x2 drop down tiles
stacker of sticks
Forgot one thing. When putting the bottom piece in, pinch the angle a little past it's 90°. When you screw it to the wall make sure it's tight. That way it's got pressure up. It just keeps everything tight, but don't over do it. Like 91° or 92° any more will start pushing the top piece up.
My trick for wall mold is screw every 8-10" but not into the studs. Wall mold does not hold weight, and you get a better finish. I just overlap my inside corners on regular mold, but I do miter shadow mold. On outside corners I run one both ends past and cut the hem off and fold over gives a nice sharp corner
Basement window tricks
Any thoughts on boxing around basement windows. I got a small job doing a bedroom and the window opening is 2-3" below ceiling grid level. I use to box them out with 3/4" Plywood dropped down 3.5" and paint it. Then put the track around it. I struggled with the inside of the frame and the finished edges. Since the window had to swing open up into the opening. I either drywalled or put a piece of plywood in there also and painted it flush to the ceiling for clearance.
Just overlap the corners then cut the miter into both with snips...
For a window box out, I've just used 1x to drop from the raised height down to the finished ceiling height (with about 1/4" reveal)
Reactions: tenon0774
1 - 11 of 11 Posts
