Go to the Register of Deeds office. Most all lots are recorded there. The original plot plan done by a surveyor should be on file or on micro film. You'll need the tax parcel number also.
I've gotten these. Draw the structure on a copy. Note the setbacks of the structure on the copy. As long as the set backs you draw in and actually build are ok, I believe you'll be ok.
I've run into towns that required the proposed plot plan be certified and stamped by a surveyor (and provide 3 copies). Then you need an "as built" before final inspection. The surveyor I used on the last one was $550 for the plot plan, and another $300ish for the "as built". Lead time was slower than yours BFD.
Other towns I've completely replaced decks, stairs, or landings without those crazy requirements. As long as you're putting it back up in exactly the same place.
I guess I'm just saying it's town dependant and you may be able to get away with We Fix Houses' idea, or at least just getting an as built would eliminate that 4 week delay before you could start building.
Worth looking into anyway. If they didn't say it had to be stamped then definitely give We Fix's idea a shot, worst case scenario they tell you "nice try".
Also, definitely do not eat that cost.
I was doing this as a favor to a friend who rents the house from him. The owner is in Spain, so we've been conducting business via emails and he didn't have anyone else even bid on it. It was a "I need this done in two weeks, how much will it cost me?". Which would have worked out fine if it wasn't for the surveyor BS. This is the first town I've run into with this rule. Its just a basic 12x12 PT deck coming down and a very over built 12x12 PT deck going back up. New everything, same footprint. The town also requires this for any front porch or landing.
They'll be watching
Westborough has drywall screw inspection also...
BFD, I'm not sure if this pertains to your particular situation, but I know some towns are tougher or more strict with contractors they're not familiar with.
I tried to be politically correct there, that's a nice way of saying what I mean.
