mjay said:
They want a clothes dryer, first floor service panel is full: So I was going to add a 2nd sub panel [30amp 240v breaker] feeding from 100amp panel in basement for the dryer.
This is where I get confused. If all the slots are full how are you going to feed the new panel?
mjay said:
But, just discovered the sub panel with vacant slot is a D model and D makes a single 30A 240v breaker, so life just got easier. Unless you disagree?
What is a "D model"? Do you mean Square D? If so then one slot does you no good. You cannot get 240v from one slot.
mjay said:
The only thing I'm not sure about is if I replace the 10/3 with 8/3 [short run 9inches] will that be sufficient for 30A 240v and a 15A 120V?
I know they recommend 40amps max for 8/3, can I let the 5amps slide [or is this the slippery slope].
The breaker amperage is not cumulative. So 30 plus 15 does not necessarily equal 45.
I think your best bet is to see if one of the panels will accept twin (or skinny) breakers. You can use them to move some single pole circuits so you can fit a two-pole breaker in. The only thing is will your panels accept twins. The label will tell you. Let us know what the label says if you are not sure.
I would also look closely at the demand load.
Are you overloading the service by installing this dryer?
How big is this place?
How many people living there?
What applainces/other electrical loads are there?
Etc....
mjay said:
Hi, Speedy, I mainly do renovations in the New Paltz area, good sparkies are hard to come by. Are you in the book?
Actually I'm not, and I like it that way. :whistling
I'm only about half hour/40 min. north of you. I really don't get down there at all. I am swamped just staying local.
I'm doing a job in High Falls right now, but only as a favor to the contractors who are good friends of mine.
Let me/us know what you come up with about your situation.
