1 - 12 of 12 Posts
Plumber / Carpenter
I know a person who after having siding installed seems to have trouble closing her exterior doors. They stick, and the strike plate dont align with the latch on the knob or dead bolt. This only happens when it is dry and no humidity. When it rains they work ok. She said the siding people used the pink insulation board on the house before they installed the siding. She had this problem every since the siding was installed, but never before that. My first thought because she lives in Chesterfield, VA it was due to shrink/swell soil conditions there. But she said she had the house 2 years before the siding was installed and had no problems.
Any opinions??
Is it just on her word that they were fine before the siding install or do you have prior experience with the doors being ok?
I do have a customer who has dark sideing on his house and when the sun hits the siding it heats up the outside of the house and you can hear all the expansion and his doors also get hard to close. She could have the same problem.
if the "strikes" don't line up ... check the "reveal" or Gap around the doors (between the header and sides) it may be that one of the doors leans over when the jamb or wall behind it swells.
then atleast you know which side is causing the problem and how to fix it, doesn't sound like a 'door' problem if it only swells when wet.
another thing is to make sure that the doors are properly sealed from mosture themselves.
It's hard to imagine vinyl siding forcing a door not to work properly. Could there be moisture problems because of the siding?
The striker not lining up seems more like ground movement, not siding issues.
rj
I have seen sideing push a door frame out of shape but it was because of a bad retaining wall pushung the sideing into the door frame.
Look the door over to see if you run 3 inch deck screws into the top hinge it will pull the door over to allow the strike plates to align and produce clearance for the door to move freely.
From what I have seen is that doors only are affected by the weather if they are real close to binding or not aligning. Another words I have never seen large amounts of shifting because of humidity.
I once set 27 doors in a house and came back to trim with a new guy... the new guy was shoving base in that was a 1/4 too long to almost 3/8 and totally bound up my doors and threw off all my cased openings...
So yes, i think if its anything other than vinyl... could be some to do with the siding.... but doubtful from installation.... unless it was cement board... that could apply the needed force to bind a door.
Did they remove any siding? Has the roof been torn off? I took 8 layers off a home while the H/O was out of town... when they got back they called and asked if i had screwed the doors shut.... I said well no (being that they left a check for me... but good idea to ensure pmnt tho:whistling)
turns out all that weight coming off bound not just the doors but some windows as well.
Or the gutters or down spouts? while installin fascia? any rain while the gutters were off? foundation settling?
I agree with the 3" screw idea and checking that the reveal is good. Should do the trick...
1 - 12 of 12 Posts
