1 - 20 of 24 Posts
I took down some stucco panels that got water on the back side, caused them to belly at the bottom of the panels, I'm replacing three there are three others that you can see they are starting to belly. I'm gonna try and draw them back to the framing with deck screws. here's some pictures
I have 40sq of that I have to rip off to replace with vinyl. The original panels were poorly installed Masonite. Home owner was sick of paying for new hardi panels one at a time
Sometimes the painters caulk too well. I did some rot repair on the upstairs section of a house overhanging a pool that the painters caulked the drip edge at the bottom of the siding. In three short years the outside floor joists (doubled at that) were almost rotted through. Mildew was growing through back of the crappy Masonite siding. I could not find anywhere that water was getting in behind the siding, but moisture could not escape as it was sealed up tight as a drum.
Steve
The reason the panels failed was cause of the Painters not doing their job. Here's where the water came from:whistling
I will be replacing three panels, but with the two different styles of stucco panels the size of the Hardi stucco boards are 4'x8' sheets and the stuff that is up on the house are 10'x4' sheets so I may have to work something out to line up batten boards, but there is water damage on other panels so I may have to refigure the whole side of the house with all new hardi stucco board. here's some pictures of hardi stucco panels.
Discussion Starter · #10 · (Edited)
Paulie
I don't know if it's me but those windows don't have any trim or case mouldings, was this a HomeOwner build? I would have trimmed those windows out with some type of trim. then you could work something in to cover the seams of the stucco boards, but these type of stucco panels need batten boards to cover the seams.
Tom I think even a couple pieces of flashing would have worked, but thats how they build them up here, cut corners were they can.
Paulie
Looking at the pictures the owner should have had the carpenter just trim those windows with 1x8 ruff saw cedar or something otherthen stucco panels, that's lame, I think wood would have worked out better
Grand Rapids Remodeling
Paulie
I don't know if it's me but those windows don't have any trim or case mouldings, was this a Homeowner build?
Yep, I framed and sheeted the addition and left it for the HO to go from there. I got a call awhile back to install the windows and doors (HO bought). I said OK and went and did that. The windows are meant for siding that's why when I got the last call for help I just figured it was double 4 or the like. When I saw what he bought my jaw dropped. I told the HO this (4x8 hardie) is not meant for this application. HO responded with "I just wanted to button it up for winter and I think it will look fine". I said OK but there will be seams that show he then walked over and held up a bag with 5 tubes of caulk. :eek:
I helped him put it up just shaking my head the whole time. The HO loved it, he said it looked great. My stomach turned looking at it, I can't stand doing doing s**t half ass ed like this. Even if I used battens it would look pita in this application, it's a wall of windows. :censored: That's why I was thinking of floating the seams and blending the stucco pattern. I was going to do it for just materials cost just for the principle.
Discussion Starter · #13 ·
HO likes it :laughing: Some people hey, Yeah you could use masonary caulk it's grity but it's caulk:rolleyes: you know it will fail at some point. you could open a bigger gap between the panels and then use wire mesh then use some mortar add some sand and Latex Fortifier that may work, but man this is a pain, the other thing I was thinking maybe strips of lattice adhesive caulk and finish nails to cover the seams paint same color as stucco panels. I don't know Paulie this is a hard one, HO's sure can throw a wrench in the engine work can't they:laughing::no:
Z flash in the horizontal joints then the trim boards is how we did it when I was framing.
Even if the painter would have cualked chances are in a year it would have had gaps anyways at least with the flashing it wont allow water behind the lower sheet
I hate stuccoto (masonite) , its gotta be the cheesiest siding I know of but hey its cheap and easy.
How does that wall breath?
Isn't there suppose to be a way for air to circulate behind the stucco so it can dry out.
I have seen local Stucco crews here in Vancouver use rain screens and vent strips so the stucco can dry out. And I see no flashing at all around the window or horizontal wood trim.
Your install looks like stucco up hard against building paper.
Perhaps the codes haven't changed in your parts.
Your repair looks good but I'm guessing your back every 3-5 years for the same problem.
1 - 20 of 24 Posts
