Nutt'in??
It is wicking water up through the footer, wall footers don't have a vapor barrier in them and they wick up moisture, that is why elastomeric paint on all 3 sides are a bad idea.I get a call from a guy about a stucco problem. Here it is.
It's about a 10 year old free standing block garden wall. 6' tall with a stone coping. Customer says he had a few spots, couple feet in diameter cracking and falling off. He had a stucco guy come back in last spring and chip off the loose stuff and re-apply stucco, then paint with some high-end flexible paint.
He also cut out the joints in the coping and it appears, caulked them. The whole repair looks neat and tight...but,
In the spots that he said had the problems, you can now see a slight bulge starting right on the head and bed joints of some of the block. I don't see how water would be getting in there. The repair looks real tight. I don't know if this happened as they were applying the repair (soaking wet joints?) or if it just started a couple weeks ago as the owner stated.
Any of you stucco master know what may be going on here?
No it's not on wire or foam.
I told him he may have to just cover it up with an EFIS type system.
The water is not coming in from the top of the wall, it is coming in through the footer.The cap has an 1 1/2" over hang, as I said before, the cap joint repair looks real tight.
Water could be wicking up from the ground, but it was redone in the spring and we haven't had any freezes yet.
Thanks for the good point about the wall being totally sealed. I'll try to get some pictures this week. I told the guy to wait and see what happens. If it's going to get repaired again, waiting isn't going to hurt.
It isn't rocket science, concrete wicks moisture from the ground and when you encapsulate it with elastomeric coatings you get these kinds of problems.
With walls you have more problems with mositure wicking up the wall than coming in through the sides, if you want to keep water from coming in from the top, use elastomeric on the top but not the front and back side of the wall.
Not sure if EFIS would fix it or not but if you can get the front and backside of the wall stripped of the elastomeric coating, fix the wall, paint it with a paint that breathes, like a satin or a flat paint, it should be OK, it is not a bad idea to coat the top of the wall and maybe 6"-12" down the front and back from the top with elsatomeric, it will keep water that sits on top of the wall or gets on there by rain from soaking into it.Thanks bwalley, so pretty much the guy is fawked? :laughing:
I'll tell him to EFIS it....and let his grand kids worry about replacing the wall.
