If sanders aren't effective or if you can't use em without destroying the ornate details, then chemical strip is the next best thing. Infrared strippers could work, but you'll need to find one that's cost effective to purchase, (good luck). I wouldn't even consider using a heat gun on a customer's home. 30 years ago yes, but not now. For chemical stripping, methylene chloride is by far my least favorite and rarely used. There are some citrus & soy gel strippers that could work, but you won't find them at a big box store, and their success is dependent upon what you're trying to remove.
My #1 choice is caustic soda beads, (aka Sodium Hydroxide or Lye). Mix with water and a bit of gain dish soap. Use pump sprayer or even spray bottle. Head-to-toe PPE required. Gotta mask off perimeter extremely well though, since it'll strip anything it comes in contact with. The dish soap keeps it from drying out too quickly.
Spray entire area, and much like stripping popcorn ceilings, go back and re-spray a small area, then attempt to remove what you can. Stiff nylon brushes, scotch-brite pads, & puddy knifes to aid. Depending upon the type of paint you're trying to remove, it may take several applications, but it's easily re-applied and removal is quicker than sanding when you're dealing with ornate & figured structures. Keeping it wet is the key. If it's dry, it ain't workin. That's the biggest issue folks have with Peel Away, since once it dries, it sort of reattaches itself to the substrate. Once you've removed all layers that can easily be removed after re-spraying it, re-spray it again as well as the next section, and move on.
Follow up with oxalic acid. The sodium hydroxide will immediately darken the wood, and the high alkalinity will throw the pH of the wood outta wack. Oxalic neutralizes the pH as well as brightens the wood.
I've used this method to strip just about everything inside a home as well as most solid deck stains and varnishes. It's efficient & effective, but needs to be done responsibly in order to prevent harm to you as well as your surroundings.
Caustic Soda Beads
