12 and smaller, solid unless specs or manufacturer dictates otherwise.
10 and larger, stranded if at all possible.
Thanks woodchuck. I guess I should have mentioned that in my area, all work is required to be in EMT. I'm going to edit the OP to reflect that.For me it depends on the job and what requirements are agreed upon. Anything in EMT/Conduit is stranded but most other work is solid wire. I do however like to use Ideal Pigtails for most connections as they are 12ga stranded copper with a forked connector so the connections can be pushed into the back of the box and there is less stress on the device.
Absolutely true.Stranded is certainly easier to pull.
Electrically, there's some theory I learned decades ago--and don't know if it's been disproven or not--that says electrical current tends to travel mostly on the "skin" of a conductor. If that's truly the case, stranded would provide much more surface area for that flow and therefore be significantly more efficient.
Good point. I do not think it is necessary to involve physics when discussing wires. The if the UL and NEMA consider a wire as sufficient to carry a load, that's OK with me.And this is why, when you drive by and look at an electrical substation, many of the conductors look like pipes.
Well then, let's throw Ohm's Law out the window.........Good point. I do not think it is necessary to involve physics when discussing wires. The if the UL and NEMA consider a wire as sufficient to carry a load, that's OK with me. ........
Why is there an ad in your post? :blink:Interesting replies. Especially about the skinning effect.
Common sense would tell me that the electrons would "skin" to the outermost surface. (Including the assembly of all combined strands, thus making stranded and solid about the same)
Am I wrong?
It looks at this point that I am going to stick with solid 14's & 12's.
SMILEY AD REMOVED
?-The dremel ad? or am I missing something else. (I usually am:laughingWhy is there an ad in your post? :blink:
Well, anal-ytically, that's the outermost surface of a solid conductor. Stranded wire consists of several solid conductors, which at the atomic level are miles apart except at the ends where they're crimped or otherwise compressed together.Common sense would tell me that the electrons would "skin" to the outermost surface. (Including the assembly of all combined strands, thus making stranded and solid about the same)
?-The dremel ad? or am I missing something else. (I usually am:laughing![]()
