Step by step H Bar with trim coil
7988 Views 18 Replies 5 Participants Last post by  Roofcheck
Here are the steps to make H Bar for soffit.
1 - 19 of 19 Posts
Step one- I mark 2-1/2" finish face
3/4" deep pocket-
Flipped and 1/2" - 5/8" thickness of the soffit.
I have better luck hemming this bend tight on the last step.
Reverse for the other side.
Almost there...
Hem tighter- not too tight or the back telegraphs through the face.
Slick work with the brake!!
Reactions: 3
If I need a H piece I use 2 pieces of J back to back with a hemmed piece to cover the center. Gets really hard to make 1/2 J or H for aluminum soffit. 5/8 is about as small as I can go with my Tapco without really working it.
I prefer to do it the way faster and tighter
Nice ,but still hard to make that fit tight for aluminum soffit. :sad:
Typically your only making a short piece so you can jam it into the break and get it 5/8" no problem .
Ill be honest on small stuff, i just miter the soffit together with 1/4" gap and the take a piece of metal the same width as my facia lip hemm it on both sides and nail it up
5/8 is just not tight enough for 1/2 and under aluminum. When you take the 2 pieces of J back to back and make a hemming piece that is not to tight it sides right on the j making it look like factory H. I do this in place too.
I started making these like this, but the non "J" pocket side never laid tight to the soffit like I wanted- and only in retro work with full blocking/ plywood can this be used.
In new construction and just sub facia and wall track (J, F or Cove) the one sided pocket doesn't work.
I don't use aluminum soffit- but the J for aluminum is tighter and looks like it would do the trick.
My brake days started on a Tapco Windy and progressed through the 14" and onto the 19"s. Windy, I don't know but any if the other Tapco's no problem making the 1/2" pockets- I'm showing 1/2" - 5/8" in the pics.
1 - 19 of 19 Posts
