1 - 3 of 3 Posts
Have a door set - exit from restaurant - metal door and frame - opposing hinges - orig metal backer in door and frame is broken.
Can these be used for opposing hinges without conflict in the jamb / door space ?
514033
That looks like the part that gets spot welded inside the frame for the hinges to screw in to. Can you drill out the old one, fish that in and spot weld it where it needs to be? If not then you should consider a full piano hinge (roton)
I dont think it needs to be welded, the holes should be threaded. Pre drill frame, slip that in and new screws
only way to tell how much room there is it remove 1 screw and use a probe to check depth. That piece shown should go behind existing hinge plate thats welded on
1 - 3 of 3 Posts
