Hi All,
This is not quite a HVAC question, but I figure you guys might be able to answer a static pressure question. I am building a spray room to do finishes for cabinets. I am planning on using a tubeaxial type fan, 36" diameter 6 blade fan powered by a 3HP 3 phase electric motor. The room is 18' x 9' (x 24') in cross section and the code is for 100 feet per minute. The door opening is 5' x 7' and will have filter material on it. The fan output will be through the wall into an auto-shuttered vent with filter material before the fan. I need to maintain 16,200 CFM to stay with the 100 FPM code. The fan has these ratings for static pressures.
[email protected] In. 17570/98
[email protected] In. 16890/98
[email protected] In. 16135/97
[email protected] In. 14450/98
[email protected] In. 12345/100
I think that the SP will increase as the filters clog, I know that the load will, which is why I picked a fan with greater capacity. Eventually I will need to place an output shroud/filter unit on the exhaust of the fan also, but that will come later when the budget permits it.
What I would like to know I guess, is this fan going to cut it? And what are the slashed numbers after the CFM rating (17570/98). How would I be able to calculate various SPs, or do you need a tool to do some measurements? Any other SP information you could give to me would be appreciated. Thanks
Leo
Leo
