1 - 4 of 4 Posts
I am having a problem using Brad Nails in this stapler. I can see where to load brads but can't get them to come out when I press handle? Does anyone have a manual on how this is supposed to worK?
UPDATE!! I finally figured out where you need to load the Brad Nails in order for this gun to work properly. Load the nails in the same tray as you would staples but place them against the left side. When you close the tray make sure they are all the way to the front of the tray. There is an ARROW on the bottom of the slide that points to which side to load the brads into. I hope this helps anyone who reads this post!!
1 - 4 of 4 Posts
