Stamped Concrete Drive
13K views 14 replies 13 participants last post by  Bull Trout
How tough is it to do a stamped drive? I am a GC and haven't done these before, building a home for myself and the wife wants a stamped and stained drive. I can rent the stamp forms but would like to know if this is something someone with general knowledge can do? The bids I am getting for this in New Orleans are pretty high between 9 and 11 a sq ft inc materials. Seems high to me based on pricing I have seen else where $3-6 a sq ft.
#6 ·
As far as for how tough it would be, I suppose a good worker with good common sense can do most anything but concrete, like asphalt, has a workability window and if you dont have your act together the cost and work involved with removing it to start over will be very aggrevating.
Pricing? I never did stamped concrete my self but I can tell you out here concrete is about 110.00 per yard. At 6" deep, which is what a driveway should be, that alone is 2.00 per sq ft. So who or how anyoyne can do the job for 3.00 is beyond me.
I would think 10 or more per sq ft for out here but in La.?????????????/
#7 ·
The stamps are expensive. They can be rented also, still expensive. Plus you have to buy the release agent/stain. About $100 for a 5 gallon bucket. I just did a driveway about 33 yards and used two 5 gallon buckets. One a dark blue and the other a brown color. You need to use a tamper. And I would get a chisel or a roller for any touchups on the joints. If you have to use the stamps anywhere next to a wall or curb, you'll need to get one floppy stamp to be able to get into the hard to reach places.
Here's some pics:
http://picasaweb.google.com/briankfranks/Work/photo#5114681386118619602
Set of stamps
http://picasaweb.google.com/briankfranks/Work/photo#5114679702491439538
Spreading the release/stain and tamping the stamps:
http://picasaweb.google.com/briankfranks/Work/photo#5114679766915948994
I think it's pretty easy, but the release is messy. Be prepared to get really dirty. If you can do concrete and finish, the stamping part is easy.
#11 ·
Nice work Cali!
We just started doing a little stamping, and as stated above, a driveway isn't the place to learn. If you can, go watch someone else doing it, or at least try a small walk or something first. The best results we have had is with color hardener bull floated in, and a dry release accent dusted on. Powerwash and seal a few days later.
#12 ·
Driveways
A driveway is not something you would want to learn on. A stamped concrete driveway might be tempting. Stamped concrete is concrete that is patterned and/or textured or embossed to resemble brick, slate, flagstone, stone, tile, wood, and various other patterns and textures. Stamped concrete is commonly used for patios, sidewalks an driveways
#13 ·
stating the obvious is when you tell someone something they already know, even 11 years later
