1 - 18 of 18 Posts
I am fixing to do some stair treads in cherry and i can't decide which way to go about it. First choice is to have 3/4 flooring and a 1inch nosing piece rabbeted out on the bottom to match the 3/4. Second is to glue up treads out of 3/4 stock with biscuits and the same 1" nosing piece. I know the flooring would be faster are there any other advantages or disadvantages? Thanks!
chief pencil holder
Buy 5/4 treads. Or glue up and mill 5/4 treads. Final dimensional thickness needs to be 1" clear, or they will crack and warp. I was in a house I installed 14 years ago a few weeks ago, it was the first solid tread job I ever installed. The treads still don’t squeak, and look great. But they are real treads. Flooring glued down will last 2-3 years tops. You will make money because it will last long enough to get you out of warrantee, but that is it.
You will be able to find cherry stair treads at any flooring supplier. Also many mills offer glue up services.
LOOK AROUND. Make a few calls. seems silly to reinvent the wheel.
P.S. please put your location in your profile. Can't send you to any one if we don't know where you are.
Steve
I vote for buying the treads. I just completed a 15 step conversion in my house from carpet to oak treads with white risers. I had some 5/4 left from other jobs. DAMN at the time it eats up, planing, edge joint, glue and clamp, planing final thickness.....
No way could I price out a job and plan to make the treads.....
Just my 2 pennies worth
chief pencil holder
Oak treads I always buy, they are so cheap it is ridiculous; I am paying $25 or so a tread for 48" unfinished. Maple about 50% I buy depends on what the local flooring company has in stock. Other woods I always make cherry, walnut, mahogany, exe. The cost on those justify the labor involved in manufacture, also you can get better looking treads.
copycat
You need at least 1" thickness on the treads. I always purchased the treads it saves time and ends up being cheaper. The treads I work with are usually 1.0625".
Buy the treads and make the returns if you need to out of the same material. Thats your best bet.
1 - 18 of 18 Posts
