Status
Not open for further replies.
1 - 2 of 2 Posts
Hello Everyone,
I'm looking for some advice on how to proceed with adding manufactured stacked stone to areas near the foundation of the house. There was previously brick in these areas. I hated the look and as I tore it down I discovered rotted sheathing. Fortunately there was no damage to the frame. I wanted to tackle the project myself but I was hesitant after learning about the possibilities of water damage. I have solicited three different contractors.
#1 - Moisture Barrier, Cement Board, Adhesive.
#2 - Moisture Barrier, Hardiboard, Scratch Coat, Mortar. (I read Hardiboard is not recommended for exterior use)
#2 - Moisture Barrier, Sheathing, Diamond Lath, Scratch Coat, Mortar
I want to do this the right away without worry of water damage down the road. The areas on the house will be exposed to outside elements such as rain and overspray from the sprinklers.
I had planned on doing:
Sheathing, Moisture Barrier (2 Layers, Tyvek + 15lb Felt), Durock Cement Board, Metal Lath, Scratch Coat, Mortar, Stacked Stone.
Is Metal lath necessary with cement board? Per the manufactures instructions it's not necessary but have seen contradicting articles online.
Other relevant info: Area is about 500 SQ, Foundation of the house, and I live in California (No Snow, temps range from 30-115).
Capra Aegagrus
Remodeler
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Homeowner and/or Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to Register
1 - 2 of 2 Posts
Status
