Status
Not open for further replies.
Squaring a deck
23K views 206 replies 36 participants last post by  Tinstaafl
This deck is whipping me when I check the diagonal it's showing 5/8 out
When I check length and width it's showing over three inches for the life of me I can't figure out what I'm missing
#61 ·
After noticing and reading this thread, I've added the correct 'diagonal for square' measurement to the deck calculator at https://www.blocklayer.com/deckcalculatoreng.aspx (thanks for the idea)
I think Railman is right 'Cant square something up that doesn't have parallel sides'. But it happens.
And reading from top or bottom of tape is not going to make any real difference.
(Ducking for cover)
The thing that amazes me most though, is that the US (you lot) still cling to Feet and bloody Inches. We changed over here (Australia) in the 1970s. Best move we ever made. As far as teaching kids goes, WTF would you teach them Feet and Inches in a Metric world?
#63 ·
(Ducking for cover)
As the world's biggest economy, we never had to go metric.
As the world does though, we'll slowly learn to use it.
#66 ·
they actually did try to teach it here in parts of the U.S. i remember them starting to teach it when i was in 4th ,5th, or 6th grade (mid/late 70's), can't remember when exactly. very unpopular and didn't last long.
that was trying to teach it after already learning american. metric is probably easier if you're taught only it starting off. i'm basing part of that on looking at a metric tape, you're just counting numbers, no fractions. of course, you gotta know how to count.
#70 ·
If you're OCD, metric tapes are better because It's marked to 1/25th of an inch, which makes it 50% better than the 1/16 marks on inch tapes.
The down side is that trapezoid you built is now out by 8 instead of more than 3. Time to panic...
#76 · (Edited)
It’s a conspiracy by the tool and fastener industry to force everyone to buy both metric and standard tools. It probably adds like 100 trillion dollars a year to the us economy.
I worked aerospace for over ten years and EVERYTHING is standard. We were a global supplier, shipped parts all over the world for big and small aircraft manufacturers, obviously Boeing and AB but also smaller Swedish, Israeli, Brazilian, etc. manufacturers. Automotive is moving more and more metric. One would think the exact opposite would be true being air travel is global and cars are local.
Pretty sure it’s still international rule that to be a pilot you need to be proficient in English too.
MAGA!;)
#79 · (Edited)
Oil plug on my gmc is 14mm
Whenever I work on an auto I always grab 2or3 wrenches for a fastener, unless I already know what it is. If it looks like a half inch I’ll grab a1/2”, 12mm and 13mm wrenches. That’s the worst part, More wrenches to haulout, clean and put away.
#120 ·
..... And whatever you do, don't mention the Mars Orbiter..
https://edition.cnn.com/TECH/space/9909/30/mars.metric.02/
It must have had a Metric oil plug?
When we changed over, some of the older tradesmen used to mix the 2. They'd read up the feet and inch side of the tape to near the metric number, then go across to the metric side to finish off, and come up with measurements like '12 feet 3 and 17 mill' (A bit like NASA)
Status
You have insufficient privileges to reply here.
