1 - 20 of 23 Posts
Full article here: Insulating a Slab With Spray Foam
Why SPF? In cold climates, insulating under a concrete floor is just common sense. But it’s fair to ask why SPF should be used instead of rigid foam board. Perhaps the greatest advantage SPF offers is that it provides a monolithic layer of insulation, with no seams or other imperfections in the thermal barrier. Because it bonds aggressively and completely to just about anything it contacts, the foam creates a superior vapor barrier around plumbing and other slab penetrations
Detailing foam board to provide an equally tight barrier takes time and great care. Getting the substrate sufficiently smooth and flat to evenly support the board takes a lot of effort too. SPF, by contrast, is totally forgiving of irregularities in the substrate. And as soon as the SPF cures — within 15 minutes — it can be walked on without concern for punching through into a concealed void (Figure 2). There’s also far less waste involved with SPF; there are no off-cuts or other discards. We can spray the exact amount required. “Extra” foam goes to the next job instead of into the dumpster.
Cost comparison. The material cost for spray foam is higher, but once the labor to properly detail rigid foam board is taken into account, the installed price becomes competitive. Our installed cost for a 2-inch layer of closed-cell foam runs about $2.20 per square foot. Two-inch polystyrene board costs around $1.80 a square foot installed, but it has a lower insulating value of R-10. Also, the bigger the slab area, the more labor is required to detail foam board around the perimeter and penetrations. On slabs 2,500 square feet and greater, we often reduce our price slightly, which ends up making SPF the less costly route. And because of the time saved, the slab pour can be moved up in the schedule.
How long has closed cell spray foam been around? No worries about it deteriorating under the slab and leaving a big void in 10 years?
That's exactly my thoughts about any kind of foam buried like that. Even worse, when foam is used under footings. These applications just aren't time tested.
Thom
I put 2" of extruded polystyrene under the slab of my own house 26 years ago, no problems yet. All the bearing walls sit on separate footings and stemwalls that are isolated from the slab. The slab is heated hydronicaly. Seems to work for me.
Very Interesting, good article.
The only question i have is why bother with SPF? Rigid foam board does have it gaps, but is there a big enough gap to cause a slab to raise?
I have never seen rigid foam fail, if installed correctly.
The cost is very surprising as well. What would one use to spray it on with? I find it hard to believe it cost more for a few guys to lay out the rigid foam board.
Would i have to get a company to come and put it in for me? I would have to wait till the next day to have them come in, when i have 3 guys on site...i could have the job done that day and be pouring the next morning.
The only place i can see it being quicker is in big jobs, were there would need to be a lot of rigid foam board.
Seems like one guy didn't have an easy time doing it, down in the comments section.
-Bill
You're talking about rigid foam panels right? Isn't there a difference between them and a sprayed closed cell foam?
Yep, one is made in a factory with computor control on the menu. The other depends upon a guy at the site to keep his eye on things and make sure the ingrediants are correct.
I don't trust site foam at all. I have 70's foam that I have removed from my house as I remodel rooms. That was sold as being the be all end all!:eek:
I think you are correct in questioning this Mike.
Project Superintendent
Around here, this is done only at the slab perimeter,if it is done at all. I'm sure it is more important in colder climates.
It just doesn't seem to make sense to me to spend all that time compacting a subgrade, have a geotech do densities, probably rip up and recompact at least once, then spread 4" stone, compact, and then put a 2" layer of styrofoam under the concrete slab. What kind of density do you get with styrofoam?
Discussion Starter · #9 ·
I'm not sure I follow you. It sounds like you are associating all that work because there is spray foam under the slab?
well if the foam is rated for the psi required isn't that all that is necessary?are we talking spray foam degrading or dissolving somehow? i think the only thing that affects cured foam besides heat is UV exposure
Sean
I was skeptical when I first saw the title, but after fully reading it, that actually makes a lot of sense. Any divets or depressions in the ground are fully filled unlike the foam sheets placed directly over the ground. Complete seal around all pipes is easier. No seams for water leakage, or radon? to enter
The only catch I saw was operator error & calling in a sub, but that applies to anything we do. As for the comparison to the foam of the 70's - that is two completely different animals & as the saying goes, we have come along way baby.
KemoSabe
No problems with this ridgid foam install. Steel needles were added to the mix before the pour. One layer of welded wire to attach tubing, then another layer on top to get into the pour.
Discussion Starter · #13 ·
Never heard of steel needles in concrete. Have had the fiber added.
Adding lead to paint sure sounded like one hell of a good idea at the time. :laughing:
KemoSabe
:laughing:
These are the ones that were added, although I can't recall the ratio that they were added per yard. They don't produce the hairy appearance on the concrete finish like fiber mesh.:thumbsup:
Discussion Starter · #16 ·
Polyurethane may have been around isn 1954, but sprayed closed cell foam used in the construction industry? 1954???? We know already that it deteriorates under UV, we found that out the hard way I'm sure. How else does it deteriorate still yet to be discovered the hard way too?
I think the spray foam method has merit, but I'm just cautious about being the Ginnie pig.
No what I mean? ;)
actually i read the wiki and the UV degradation really only happens on the very outside,leaving the Pu just under it unaffected
possibly contaminated soil could affect it?
absolutely i no what you mean Mike.i wouldn't want to use something i wasn't sure of
but...what do you do,look at the science which most here don't really understand and go with your gut i guess
Discussion Starter · #18 ·
I think that's what we all have to do. It's always safer to do an incremental change, like just adding a little more oregano to your spagetti sauce, compared to switching to tofu meat balls instead of meat.
I'd like to find out how long closed sell spray foam has been around being used in the insulation business. Seems they are also mixing up a lot of new versions of it now aren't they? Aren't they doing soy based now? To me that's another big change and variable added to the equation. That is like changing to tofu.
KemoSabe
No what I mean? ;)
The problem is, construction technology is an evolutionary process. If you don't get in at ground level, you end up playing catch-up with the guys who are vastly experienced because they were on top of the "fad". Unfortunately, they are always going to be the Guinea Pigs in the process. Dri-Vit is a great example. Also, 25 years ago, I would never have imagined that vinyl siding would revolutionize the marketplace. Now vinyl is old technology but PVC trim is all the rage. Cementitious siding is an old technology that is seeing a resurgance because it was and is a great product. I guess you just gotta roll with it or get rolled over by it.
Reactions: Mike Finley
Discussion Starter · #20 ·
All I know is this closed cell spray foam is really getting to be the new rage in building. It's showing up more and more and in more and more applications. I just hope it doesn't end up being another asbestos or similar super product that turns out to be a huge mistake.
The human race has an interesting way of meddling with all sorts of things that make up our world to try and make new stuff. Sometimes it leads to poisonous substances that cause more harm than good and other times it leads to useful substances that have a wide range of uses in many different areas. One of those ‘inventions’ is polyurethane foam. Most people know about it, but most people do not really know what it really is. This article is not about to try and explain just what it is, but rather one its many uses – especially as regards closed cell polyurethane foam. Closed cell polyurethane foam is often used as insulation in houses and other buildings. There are many advantages as to why this type of foam makes such a good insulator aside from the fact that it is easy to install if you have an experienced foam contractor doing the job. It can be installed in nearly any building and any location and it does not require a lot, if any maintenance.
1 - 20 of 23 Posts
