If you don't have the problem when you use the old stat by wiring it up at the outside unit. It tends to indicate that the problem is in the wires from the stat location.
The thing about the wiring at the stat is that I kept the back plate of t-stat2 connected while "using" t-stat one at the heat pump.
At that point, I got normal readings both on the wires to the hp and normal readings on back plate-2. That is what has me stumped. If the wiring was faulty, wouldn't you expect to have the same problem?
I tried several wiring configurations: (hardwired wires at stat, wired r @ the a/h to y to the heat pump and kept the stat wires out of the circuit, and always there was voltage on the o wire). I never even thought about by-passing the defrost board on the heat pump.... Not only should I say thanks to Gene, but Thanks a lot:thumbup:.
Well, I left the o-wire as a temporary fix, but thanks to B.T. and Gene, I have some better ideas.
