Thanks for the responses guys.The area I'm doing is in a walk out basement,where three of the outside walls are completely above grade and
one wall has 4' of foundation below grade.The resilient channel will be on the uninsulated ceiling,over existing drywall, in this area.I plan on using 5/8" drywall.
My concerns are with the humidity level,since all the exposed water lines have been wrapped with insulation to prevent dripping in the past.
These pipes will be buried in the ceiling but accessible via a chase.
With the recent concern over the use of light weight drywall failing.I wanted to ensure that this method doesn't accelerate or contribute to future problems.
My yard only carries the LW dry wall,so I guess I will look for other sources of material to eliminate that concern.
Two dry wall contractors suggested the same system so I'm confident in its performance,I just can't wrap my head around the floating/bouncing as mentioned by Big Shoe.
I'd imagine the walls are gently butted to the ceiling to alleviate any further sagging that may cause the taped corners to fail,but knowing what happens to wet drywall,and the inherent humidity level in this application,couldn't the drywall also curl up at the corners and cause the tape to fail?
I've informed the HO of my concern,and hope he controls the humidity as I suggested,but people forget and any failure of the system could come back to bite me,so I want to take as many precautions as possible here.
