1 - 6 of 6 Posts
Hey guys,
We are putting a hot yoga room in our house, and it sits right above our daughters bedroom. Right now there is 3/4" T&G subfloor and it needs another 1/4".
What I'm looking for is something I can put in between the two layers that might reduce the noise to the bedroom below. I know there are a lot of sound proofing options, but I don't want pull up the existing floor and any noise reduction would be good.
Any thoughts?
Manager/Diplomat/Builder
I've used some construction adhesives that help reduce sound when installing Sheetrock. I bet they, or a similar product is available that you could use between the existing subfloor and your 1/4" filler.
There may be better options out there, but someone who does more sound proofing work will know more then me.
One of the cork, rubber, or foam underlayments will reduce impact noise from hard objects (shoes) and might help with some medium and high-frequency noise (voices, music). Your finish floor can't be nailed, though - either glued or floated.
There are no silver bullets with sound reduction - you need multiple approaches, all done very carefully, to have a significant, broad effect.
Maybe a little extreme, but what do you think about blowing in insulatioin, in the floor joist cavity.
You could drill your holes in the upper sub-floor and fill the void. The holes will get covered up with the new flooring.
I dont know what a hot yoga room is nor do I know what kind of flooring goes in one but could you put down some type of foam or rubber flooring to soften the steps? Kinda like some of the gym floors.
1 - 6 of 6 Posts
