21 - 38 of 38 Posts
Decoupling really is the starting point of proper sound isolation. I would never ever recommend resilient channel for several reasons. The factory damped dywall mentioned is pretty pricey for what it does. Better on many levels to use a separate damping material and standard 5/8" drywall
Contractor of the Month
Ted what is the "separate damping material" that you speak of?
Prices range depending on where purchased and how much is applied per square foot. A medium application rate may cost $0.55 - $0.85 a square foot, again depending on the source.
Ahh gotcha green glue is excellent but you have to weigh the cost of carrying in and laying twice the sheetrock.
Performance = mass. That's the primary soundproofing driver. The cost to hang a second sheet is small. Maybe $0.20 a sqft? Varies geographically.
Compare that to the cost of waste associated with throwing away the scrap exotic drywall. Assuming a 10-12% waste factor, that's throwing away over $8 a sheet into the dumpster. That's the cost of a brand new sheet of standard 5/8"
There really aren't any numbers that justify the expense of pre-damped board, especially considering it it a lower performing option in addition to being 2X the cost
Commercial Contractor
Green Glue really does help. It's a great product.
Only been spec'd on two projects, but it seems to really add to the quality of the soundproofing. That is, a properly designed system, no one material makes the it more advantageous.
If I remember correctly, it was a tube per sheet, between the layers.
EDIT: By the way, I was paying $250.00/box, with 12 tubes per.
You might want to shop that price. That's more than 2x what it sells for elsewhere. And tubes are more expensive than pails.
I think it was due to my supplier not stocking it, it was special order for them on both projects. Also only been around here for a little over a year I think, but it's obviously picked up in popularity.
I got the 4x10 5/8 drywall for .14/sqft, and my RC-1 for .90/LF though.
I think I came out alright!
Man! What a great price on the drywall. Wow!
for 10' 5/8" yeah! They always do very well with drywall and metal, but that was better than usual for sure.
Can only assume they really wanted the order.
I hope your right though and as GG becomes more of a mainstay in this region that the price lowers.
For instance, none of the suppliers here even knew they came in pails, you just informed me of that. Also one needed a whole day to figure out what it was and get pricing, so its still a baby here.
Keep in mind that a soundproofing company can ship this stuff efficiently via UPS or even a small pallet. You might find that a better way to go, since the specialized soundproofing company can also offer detailed advice, schematics, etc that a drywall distributor cannot.
So you get access to the lowest cost product, no tax, low freight and all the free design advice you can stomach.
Hi, I am looking to improve the soundproofing of a wall that currently has the following:
  • Sound'n Safe Rockwool
  • 2 gypses 5/8 with GreenGlue
It's ok but still hear the low-frequency bass from my neighbours...
I would like to add Sonopan panels and resilient panels + 2 gypses panels. My question is to know if it would be more efficient to remove the current 2 gypses + green glue and start from scratch by covering the rock wool with Sonopan + resilient channels. + 2 gypses...
Or if I could directly put the Sonopan and resilient channel on top of my current wall. At the end, it would contain the following: Safe'n sound rockwool + 2 gypses with greenglue + Sonopan + resilient channels + 2 gypses.
Thank you in advance for your advices.
Best
Éric
Goin' Down in Flames....
Highwayman
Best
Éric
First of all, you should start your own thread for best results, rather than piggy backing on a ten year old one.
Second, this is a site for professional builders only. If you are employed in the trades, go to the intro section, tell us about your work, and then start your thread. 👍
As a person who built their own recording studio, I think you should make sure you have measurable metrics and have educated the client (and perhaps yourself) that low-frequency absorption is prohibitively expensive and is often the biggest complaint that brings people in for "sound proofing" (unless you're building an apartment sized anechoic chamber, this isn't happening)
21 - 38 of 38 Posts
