1 - 17 of 17 Posts
When you aboriginal airing up to your electric panel, the aboriginal affair you will see is the cover. Open up the console aperture and central you will see all of your ambit breakers. On the central of the aperture there should be an allotment that lists what genitalia of the abode anniversary ambit breaker powers.
Depending on the admeasurements of your home, you may apprehension a abate electrical console to the ancillary of the primary panel. This is alleged a sub panel. In best cases, the sub console is fed anon from a two-pole ambit breaker in the primary electric panel.
Take an attending at your ambit breakers. You will apprehension that anniversary one has a switch-type affection with "on" and "off" indications. Also apprehension that anniversary breaker is labeled for a assertive amperage, whether it be 15 amps, 20 amps or higher.
· Project Manager HFH..
· Tech Geek
Actually,it sounds like someone ran something through the babble fish translator....
I just ran it through that and got this:
that didn't work.:laughing:
Here's he link.
http://babelfish.yahoo.com/
1 - 17 of 17 Posts
