1 - 20 of 31 Posts
Discussion Starter · #9 ·
There is a void where some post work will break the transition. It was too heavy to pick up with a couple or even 4 guys thats for sure. Set it with a chain pulley.
Administrator
Sawdust follows Me Everywhere
Whatta hack :thumbsup:
come on...do a drawing, I don't get it at all, I'm looking for an obvious transition on the back side and I don't see anything, or did you use some brick on top of stone to get to a level spot where you could lay block?
That sure is a great project that shows off the visual properties of stone. - Especially in the setting.
The slightly off-center and non-vertical diamond was a great touch to avoid it looking like a "canned" use.
Reactions: JBM
Discussion Starter · #14 ·
Its just a block chimney with thin stone on the outside and a stone fireplace inside. We left a pocket for a post detail on the sides.
That's beautiful work.
I'm curious about the creative process to arrive at that design. Talk with the customer about stone varieties available? Draw pictures? Look at pictures on Houzz? Just tell to let you do your thing? Is the stone local?
1 - 20 of 31 Posts
