I think you should be fine with the standard prep. The paint may prevent the stain from soaking in, which could create an uneven finish so you may have to put two coats on to get an even finish. Solid hide stain is pretty forgiving stuff.
:laughing: :thumbup:As for not knowing what you're doing, everybody is in that position at some point. There is a very vocal minority on this site that like to play that "don't start if you aren't already an expert!" card, but I'm pretty sure every one of them are too old and crusty to remember when they too were faced with starting something new. Good on you for doing the research first.
:laughing::clap:As for not knowing what you're doing, everybody is in that position at some point. There is a very vocal minority on this site that like to play that "don't start if you aren't already an expert!" card, but I'm pretty sure every one of them are too old and crusty to remember when they too were faced with starting something new. Good on you for doing the research first.
I've just found high quality solid stains to be more durable to foot and furniture traffic than an exterior paint. Looks similar, peels off in the end the same way, but seems to last another season or so, as long as it isn't applied over a bunch or loose, peeling paint underneath it.I am old and crusty for sure.
However I do remember not knowing what I was doing.
Also I cant see the advantage using heavy bodied stain over paint. They are mostly the same Right ? One is thinned down and one is over solid.
J.
^^^^^^^:thumbsup: Me tooHeck, I'm old & crusty and still not sure what I'm doing.
