1 - 9 of 9 Posts
Chris
Not enough info to give an accurate response. Depends on the wood species, age, distance the tip is from the wood. Could be 100 psi could be a 1000 psi
Cleaning wood is probably the toughest pressure washing task to master if you don't plan on sanding, some times it can not be avoided.
1 - 9 of 9 Posts
