Soffit
8K views 29 replies 11 participants last post by  Snobnd
I have an area approx 24 x 36 that I need to enclose. It is the underside of a canopy. Currently there is plywood nailed up and painted. I was think of using soffit, with 3 J-channel joints running so it would be 3 sections of 12' soffit. Any better ideas?
#20 ·
A real man, (such as myself) Would make the H channel on the brake, in one piece. I do it whenever I can, Its a pride thing, and I like to show off with the coil
On returns runing soffits we made our own H channels all the time, but on a large ceiling you know the old saying. White, White and White are three different colors. Thats when we would use a T-Channel and J's to match the soffit we are using for the ceiling. On large H-Channels made with the coil the color wouldn't match like the T-Channel.
#21 ·
Ick, I know what you mean, I was doin good till the started chaning things around on me. We get the economy soffit, "snow" and "snow J" and white coil. Seems ok. We just finished a white house today. tommorow we will be wiping all the finger prints off
#12 ·
Ill take a picture tomorrow. I gotta think every time i go to make one, but once i do the first one, i can bang them out real quick. I use them for soffit miters cause I can make them actually 5/8" and they don't look goofy because they lay nice and flat unlike a premade vinyl one. ALSO, if you are doing colored soffit they are a lifesaver, cause sometimes you cant easily get colored H channel, and when you can its usually special order
#14 ·
YUP, looks just like the vinyl one but out of metal so its flatter. and the total thickness is 5/8" so it fits into the facia perfectly.
I drew you a picture of how I bend it. I want all you kids to make 5 a piece for homework. Make sure your hems are tight!
#16 ·
Yea, you can even make the nice and wide, like a 2" pocket so a 4" face, then it looks like its meant to be there, rather than being there because vinyl only comes in short lengths.
#19 ·
These brake made trims are not for a novice and can only be made to be the length of the brake. If your not very experienced bending and hanging coil you could spend a lot of time wasting coil. In a situation where you need more than one piece the job made pieces are hard to butt together unless perfectly made.
Lineals come in lengths up to 20 ft. H bar in 12 ft lengths.
A 3 inch flat piece of coil cut the length of the soffit run and crimped for aluminum sill trim and with aluminum sill trim on the edges looks nice to cover a long soffit seam.
#22 ·
I agree. I can normally get it come out looking good but lately I just order some aluminum j-channel and screw it together using 1/2" hex screws. It looks better and you can split the seems etc.
I did a porch a couple weeks ago that was an older restaurant patio on a golf course. It was 48x48 and had all kinds of lights and sprinkler heads etc to cut around. Paid great though because I only had to cut the lengths of the final row of beaded panel.
#23 ·
Economy Soffit
Heads up on using grey back economy soffit. We have had 3 Alcoa jobs warp out under patios. The new unpublished installation for this product requires a nailer every 12 inches instead of 16. If your not specifying exactly what soffit you want you may be getting economy and paying for premium. This was the case of these 3 jobs sent out from Lansing Building Products last year.
#25 ·
Oh YUP! No Doubt!!! I didnt specify. We ONLY use economy soffit on regular soffits 8-20 inches, and thats it. We use 2" beaded on porches and patios. The one thing thats always made me nervous about economy soffit is that its painted not solid vinyl.
