1 - 20 of 71 Posts
Have been involved with a project where the entire interior is finish with architectural grade plywood. Some rooms are 3/4" pre finished and some 1/2" pre finished. Very unique project. I have approx 160 panels to install. All exposed stainless steel fasteners in a specific pattern specd out by the interior designers.
Wow i thought the wood paneling look went away years ago. hope its not coming back.
· Read Only
WOW!
Nice change of pace methinks!:thumbup:
We do those type of panels on commercial projects all the time, lucky you get to use exposed fasteners, we always have to hang them on French cleats.
Post finished pictures when your done, I'm sure it's going to be awesome
It's definitely a change of pace, it's the modern look that they are going for, clean lines, exposed fasteners. I enjoy this stuff the best. Got the back wall finished tonight. There are plenty more panels to go. I actually like the look of it all, just has to be in the right house for me to like it.
· Design/Build
Cool design, one for the portfolio. Extra points for no drywall dust!
What happens at the joints between panels? I'll bet aluminum c channel or even raw steel would look good as a spacer. What does the detail at the floor look like?
For being "simple" I've always found modern details demand excellent craftsmanship. Looks like you got it covered.
Discussion Starter · #11 · (Edited)
EmmCeeDee said:
Cool design, one for the portfolio. Extra points for no drywall dust! What happens at the joints between panels? I'll bet aluminum c channel or even raw steel would look good as a spacer. What does the detail at the floor look like? For being "simple" I've always found modern details demand excellent craftsmanship. Looks like you got it covered.
the panels keep the 1/8" gaps as a shadow line. As for the floor we are using a plywood with a thicker veneer for the floor. The floor will keep a 1/4" shadow line along the wall and the screw pattern will carry onto the floor.
1 - 20 of 71 Posts
