yep, most likely engine oil pressure cut off switch. the problem is that you will have to buy a new one to test it. sometimes they will be filled with oil/dirt and wont work properly, clean it, clean the contacts and try again. tipically it is located on the side of the engine block, fitted through an oil gallery.
