1 - 6 of 6 Posts
Thom
If this is commercial, the size of the deck should determine the occupancy load and that should determine the minimum egress requirements.
If this is a residence and is not part of any egress path, there should be no minimum.
General Contractor
Does anybody know what is the narrowest allowed outside door? It will lead to the balcony-type deck with no fire escape.
Thanks for your help.
If it's not a required exit door, then there is no minimum size under the IRC.
R311.4.2 Door type and size. The required exit door shall be a side-hinged door not less than 3 feet (914 mm) in width and 6 feet 8 inches (2032 mm) in height. Other doors shall not be required to comply with these minimum dimensions.
1 - 6 of 6 Posts
