Hey guys,
I almost hate to ask, because it shows where I'm weak in my building knowledge, but you don't learn if you don't ask, so here goes:
I'm looking to put on a simple 16' x 24' addition to my house. The addition of another baby at the end of this year is pushing our space, and it's either sell & move up, or expand slightly. Given the economy, I can build easier than I can move!
My house is a hodge-bodge of various construction techniques, and I'm trying to tie-in several different things with this project, so that the overall result is a more modern house with increased functionality.
The side of the house I'm looking to expand has a basement, but it's an old stone wall basement. I'd like to put together the addition as a "at grade" system, with a foundation, but without a full basement.
I am very comfortable with putting a full basement together, and even a crawlspace. However, I'm not as comfortable putting together a footer-ed slab & building off of that. I think I understand the proper process, and have done it in smaller applications before, but not for a project of this size.
Basically, my thought was to dig & pour the footer, lay-up a block wall to grade, backfill and pour crete.
Once the crete is set I'd build my walls & roof (single floor).
Then install a moisture barrier, and place pt 2x4 studs flat every 16", with rigid foam insulation in between them. Then install Advantech 3/4 over the sleepers, and carpet on that.
However, I've been reading thru the 2006 IRC, and I can't find anything specific to this idea. So I turned to the search function here, but most of the posts were about putting together a floor where you need to build it up a bit- and I'd prefer a sealed system with no crawlspace.
I'm not looking for someone else to do my job, but any advice would be great. Specifically, if there is a section of the code that deals with this, and I'm missing it, I'd appreciate a "point in the right direction".
I've attached a drawing so crude, I'm almost embarrassed to show it.
However, I think it should get across the idea.
As always, I'm open to suggestions.
Thanks in advance,
~Matt
Thanks in advance,
~Matt
