1 - 3 of 3 Posts
Trial and Error Opperator
Kill, Sorry about that....
The reduction should not make much difference you will see.
If you were running all hoses from your compressor, Air Trap and blast hose with 1-1/4" ID (Inside Dia.) then you might see a change.
If you have a 1" ID hose from your compressor, No you will not see a change.
If you have a 1-1/4" hose with an end fitting that goes inside the hose, you already have reduced it to a 1"...
I think you got your regulator cheep?
try it and see, if it really frigs with it take it off.
I don't use one very offten so I may take mine and put two quick fit on and add it in line at the entry of the blast pot, then I can remove it fast and easy when done.
( the pic on the other post is Todd's)
1 - 3 of 3 Posts
