I've been hearing that alot of contractors are now useing crown staplers to put siding on. Has anyone herd of this and if so what brand of crown stapler do you recommend.
You might want to post an intro in the intro section.I've been hearing that alot of contractors are now useing crown staplers to put siding on. Has anyone herd of this and if so what brand of crown stapler do you recommend.
:blink: You never switch it up above the belly band or in the gables??The only siding i do is Board and Baton so no clue as to an answer to your question.
All I side is 1 story lean-to Ag buildings. No gables of belly bands to speak of.:blink: You never switch it up above the belly band or in the gables??
Presently, Hitachi.What brand of stapler did you us?
I modified a roofing nailer. Works dreams
ditto way faster than hand nailing and saves the fingers from well, hammers!paslode sheathing stapler with the siding tip. works great!!!
I'll take some pics tomorrowmrcharles said:Do tell
Like anthill said, one leg in hole slot, the other above the hem. Need adjustable gun so you can have space for slippage, same as you would for hand nailing. But you can adjust a little tighter for soffits where you don't want them vibrating in the wind.How do you staple the vinyl siding and still allow expansion/contraction to happen?
