1 - 20 of 22 Posts
This was pretty interesting, and I'm wondering if anyone has a solution to this problem? Luckily the home owner is ok with it.
A piece of siding developed a concave bend in it out of nowhere, the siding was replaced, then the same thing happened again right away. We noticed that the neighbors upstairs window which had LowE coating, was reflecting the suns heat and directing it directly to this particular piece of siding, causing this issue.
The siding used is mastic carvedwood, however I'm wondering that should siding have been put with form fitted insulation behind it, would it be able to resist the warping do you think?
Capra Aegagrus
Remodeler
I'm not familiar with that brand, but it blows my mind that the reflection from any window would do that. Especially in New York, which ain't exactly the sun capital of the country. Is the material thinner than normal?
To respond to your question though, I can't imagine that any kind of backing would keep that from happening--though it might mitigate it slightly.
I was at a seminar once where they talked about this happening. The houses in the pics were really close together. I think the only solution may be to change the glass in the other owners window. Sounds crazy but.................
KemoSabe
Along the Barrier islands, many of the homes are 8-10 feet apart. The reflection off of today's high performance windows is incredibly bright on the neighbors sidewall. I haven't seen this problem personally, but I've heard tell of it before.
Hey everyone.
I've run into same problem last year. It was Mill Creek siding we've installed five years ago. Unfortunately ALCOA (manufacturer) don't cover this type of damages under their warranty. We replaced few pieces and home owner planted a small tree in front.
Hope it helps
Hey everyone.
Hope it helps
LOL it was mill creek what do you expect when your hanging a $45/sq panel???
ive seen it on a wolverine restoration panel ,it was caused by a defective skylite,the glass sagged causing it to reflect onto and distort a wall some 20' away
looked like someone took a lazer and ran it up the wall,siding was melted
so if you ever see a panel like that look for something shiny,it could happen in a driveway by a car mirror or chrome trim
1 - 20 of 22 Posts
