1 - 11 of 11 Posts
Have Trowel, Do travel
Really? only 2" longer than a typical american brick...and only 1 3/8" longer than an Ontario sized brick? they look crazy long. How tall./high are they?
in centimeters. 25cm by 12cm by 5.5 cm
Discussion Starter · #9 ·
I knew you could answer that
thank you
This job i will do as if it was veneer, thinset toothed an the concrete, and the back of the brick, then every 2ft H. some rebar will be drilled into wall for added support.
the anti seismic here is of the highest category.
Reactions: Calidecks
Discussion Starter · #10 · (Edited)
off topic but Hilti is doing a seminar on anti seismic construction the 8th of november, I'll be there
Font Room Photography Advertising Brand
1 - 11 of 11 Posts
