For those who use a mud base shower pan with backer on the walls, do you install the backer board first so that it runs down behind the mud base? or do you install the mud base and run backer down to it? Ive seen both, whats the reasoning?
I install the backer board first, holding it about an inch off of the subfloor. The reason being, since you can't place nails lower than about six inches from the bottom (you don't want to pierce your pan liner), the deck mud helps lock in the bottom of the backer board.For those who use a mud base shower pan with backer on the walls, do you install the backer board first so that it runs down behind the mud base? or do you install the mud base and run backer down to it? Ive seen both, whats the reasoning?
Ummmm, you're using rubber roofing as a pan liner?I glue rubber roofing to a CDX base to line tile base showers, and I bring my backer over the edge of the rubber. Then when you pour your concrete, it'll lock it in. That way if the grout cracks, the water runs to the rubber and down to the drain. It absolutely does not let water through, even if the mud in the pan cracks (which will eventually happen if the house settles significantly.)
What about epoxy grout?You do know grout doesn't stop water, cracked or not, don't you? :whistling
Epoxy grout is much less permeable than cementitious grout, but you shouldn't rely on any grout as a waterproofing.What about epoxy grout?
:thumbsup::rockon::sad: This is why I'm confident in the way I build showers.
And why I can charge what I do. :whistling
what is the cost difference in materials between tradtional mud base and somthing like kerdi?Having said all that, I really don't build "traditional" cbu/mud base showers anymore. Surface applied, and better yet, surface bonded sheet membranes are the way to go IMHO. That way, you don't have to worry about water, or vapor penetration beyond the tile and grout.![]()
The cost difference is nominal.what is the cost difference in materials between tradtional mud base and somthing like kerdi?
I watched a video on a kerdi installation, and I have a hard time believing that it is going to hold up better and have less leakage for years to come.
Its a very thin cloth, with a dozen different seams at the base. maybe a pvc liner under the whole thing would make me feel more comfortable.Why do you have a hard time believing a Kerdi shower will hold up?
Kerdi has been out since the 1980's. Try and find a single, legitimate product failure. You won't.Its a very thin cloth, with a dozen different seams at the base. maybe a pvc liner under the whole thing would make me feel more comfortable.
It's not my goal to get into a pissing contest, but I just want to clarify.Ummmm, you're using rubber roofing as a pan liner?
Generally, concrete is not the mud of choice for a tiled shower.
