1 - 14 of 14 Posts
Butcher of wood and metal
Discussion Starter #1 (Edited)
A builder I do work for is having me put some standing seam on a new build and he seems to value my advice on things. So the question. It is a fairly low pitch roof shed style roof , will be full ice and water on it, with the standing seam, He was wondering or thinking of putting Zip sheeting on it, See any need or value in doing that , think he said it is $ 60 some a sheet. It's his call in the end .
Thanks
Discussion Starter #5
Well I suggesed that to him today. Said the HO was ok with paying the extra for it and he already ordered it. I don't think it is needed neither. Oh well tried .
Discussion Starter #9
Found out yesterday that the roof is 32 ft in length, 12" standing seam panels. So will have to figure out a plan o get them on the roof;
Longest panels I've worked with were 2'x76'. We had a few hundred feet of those lifted via crane. A guy that used to work for me did 150' panels, formed on site and lifted with a bunch of guys on ladders.
Discussion Starter #11
Think got a plan. Will use 20 ft I joist fastened to my lift then make cradle to stand the panel on edge the lift it up to the roof.
Sent from my SM-A115A using Tapatalk
Fantastic. We'd do 30-40' panels in a similar way.
We just put a strap around them at each end, making them a tube and lift from the ground.
Quick and easy if you have a ground guy. If it's a tall barn, we set up a run of scaffolding for tools and to lift the panels.
Discussion Starter #14
I can see that for 3' panel and have done it. smaller standing seam does not work.
1 - 14 of 14 Posts
