Framing tall walls but only have 8 ft. sheets for shear wall, really common scenario here in Cali, what would you do? I've always put my 3x shear block line at 8ft. then stood the sheets up. This either leaves 2ft. rips at the top or the sheathing can continue if second floor. This way there is a continuous 3x block line at 8ft. through each wall and each sheet has solid nailing on all edges. Lately I've seen a few other guys stagger their 8ft. sheets standing, with 2ft. rips alternating top and bottom. This seems like a good idea, similar to staggering floor sheathing, but it eliminates a continuous line of shear blocking. Instead you have broken up block lines that cover 3 bays and are staggered up and down the wall. It would seem that breaking up the block line would diminish alot of the walls resistance for shear, even if all the sheets have sufficient edge nailing. What do you guys think?
