1 - 10 of 10 Posts
Is there a safe way to take the edge off a travertine tile after install. A couple of tiles in a small room are about 16th high on one side. Is it possible to soften the edge with a Dremel?
You can "soften" them with just about anything. Soft stone that hones very easy.
220 grit
Diamond File
Dremel (? (I would worry about keepin' her straight lookin'))
Crumpled up paper bag......
whateva.
Sandpaper or polishing pad on grinder to just round over.
For textured edge use lag screw scraped over edge,light hammer to chisel edge or random grinder the edge.
Hair Splitter
We had a recent install with a chipped edge. The old hammer and small cold chisel did the trick.
Talking Head
I just give it a swipe with the grinder and then smooth it out with a rub-brick. For rough edge I just pause a few times when I do the grinder pass.
Lag screw?
I like. Just sounds like it would work.
6"lag acrew or eyebolt with (not machine thread) regular thread. Drag 90* to edge to chip tile edge. It produces small/ medium chisel edge but is tedious to use.
A small tack hammer is quicker
1 - 10 of 10 Posts
