Status
Not open for further replies.
Security System Zone not Working
2.2K views 3 replies 4 participants last post by  Tinstaafl
Hi,
I'm hoping someone can help. I have an old home security system that has a zone that suddenly decided not to work. The zone acts as if there is a window or door on that zone that is not closed. Obviously, the doors and windows are shut, but the zone light won't go out, so I can't set the house alarm without bypassing that zone. The biggest problem is that there are 3 doors and 11 windows on the same zone, so it's difficult to pinpoint with window/door is the culprit. I have bypassed the zone on the control panel with a jump wire to determine that the problem wasn't with the circuit board. I had a friend tell me to then pull out each of the recessed switches on my windows/doors and test those. To test them, I cut the switch off and twisted the two wires together to basically bypass that window. Theoretically, if I did that one at a time for each window/door, eventually I would discover if one of the switches was bad. So, that leads to this message. I've removed the switches from the three doors that are used frequently and the two windows that have been opened in the last few years. Nothing. Zone light still on. Rather than remove the switch on the remaining 8 windows and discover it's still not solved, I thought I'd reach out to you all to see if you have any ideas. I've attached pictures of my control panel. Thank you!
#4 ·
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Homeowner and/or Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
Status
You have insufficient privileges to reply here.
