I just finished a crawlspace remediation and got a call that the sump pumps may be have tripped a breaker....so I checked it out tonight and when resetting the breaker it buzzes then within approximately one second it trips. The onsite maintenance guy said the power supply in the high power exterior building lighting sometimes shorts out.
question: being as they look like a 175w sodium wall mount, will the power supply's some times short out (high current draw)? Don't worry, I don't fix this kind of stuff, but I thought when they go bad you'll have an open or non-igniting light; what is the likely cause?
