Situation:
Home Owner wants to add second floor. First floor ceiling joists are 2x8 over 13'10" span. Ceilings are older plaster-over-stucco-over-sheetrock (appx. 12 lbs/sqft).
So:
Ceilings need to come out, and span tables call for at least 2x10 No. 1 Southern Pine joists. I worked it at 60LL 20DL 360DF just to be sure because there will be some stone work in upstairs baths.
But is there a better way to reinforce existing joists (angle iron, flitch, sistering) as opposed to removing entire ceiling structure? Lots of wire, plumbing, hvac to deal with. ie will sistered 2x8's sub for 2x10's otherwise house will be uninhabitable while work takes place.
So:
