Hello,
I sometimes use a conditioner for soft wood prior to staining but I have received advice to seal a fiberglass entry door from the salesman and the installer prior to staining. Is this correct advice? The only advice I got from the salesman was that any sealer will do. Fiberglass does not seem to have the pore structure as wood does. So I have doubts if the advice is correct. If I need to use a sealer, what type do I used? A sanding sealer or would a conditioner work?
