Seal Tight/Connection Punchlist
1K views 6 replies 7 participants last post by  Dooi
Hi all,
I'm a bit stumped on this one. I'm not an electrician and working on a punchout for a job I've inherited. The comment made on this particular item is that the seal tight is not necessary for a proper installation and is not even connected properly. I think it's been connected properly and have no issue in regards to compliance with code. Thoughts?
#5 ·
That would be what I'd check first.... whether the flex is approved for grounding and whether there's a ground wire if it isn't.
It looks like there's a gasket on the 90, so I'd say it's not an approved ground path.
