1 - 14 of 14 Posts
Looking at a couple of Skyjacks for sale near me.
First one is a Model 3219 19' with 915.8 hrs on it.
514594
Other one is:
Make: SKYJACK
Model: SJIII3219
Yr: 14
Serial#: 22058990
Meter: 145
Price: $6,650
Any reason to be scared of the cheaper one with more hours?
They are both coming from separate rental yards that I trust.
I will also sell it in 2 or 100 years when I am done with the insulation and electrical and ceiling work in my pole barn.
Yes.
I'll never be able to drive it out of there, but the floor is awesome.
And the rough terrain lifts are 20k, which isn't worth it to me.
Sent from my SM-N960U using Tapatalk
Demo
First one is a Model 3219 19' with 915.8 hrs on it. View attachment 514594
Other one is:
Make: SKYJACK
Model: SJIII3219
Yr: 14
Serial#: 22058990
Meter: 145
Price: $6,650
What's the price for the one with more hr? I don't see it in OP.
Factory I worked at long ago had 3 in the maintenance area that I ordered parts for when they were required. When they got old the bushings at all the joints would start to get sloppy and would cause a little sway. Ok if you’re not the nervous type. The hoses and pumps were pretty standard but I’m sure a hose would be at least a C- note minimum. IMO i’d go with the cheaper one if it checks out. Check hoses joints, fluid tires etc and make a offer. Don’t remember ordering any pumps. Controls and limit switches would go bad because of operator error.
Forgot about the big one , the batteries might make the new one more attractive.
I was building branch bank about 12 yrs ago, electricians scope included solar panels on the roof. This was a free standing branch on an empty dirt lot. So they get to the panel installation before the asphalt was laid and the dumba$$ electrician rented a lift like that for his guys to work off. He didnt understand why it had trouble moving around.
Demo
If it was me, I'd probably price batteries in the little one and see what the difference is then. A lot can happen in the 771 additional hr that the cheaper one has on the meter.
Discussion Starter · #9 ·
I told the sales guy at United that I was considering the cheaper one, and he claims to have other options in that price range that are newer than that and with fewer hours. He'll get that info to me on Monday. He's starting to take me seriously now. (I imagine he gets a lot of tire kickers).
As Mesilla mentioned, check all hoses & fittings. Take it up & down a few times & check again. Take a clean rag w/you & swipe fittings. They clean em up well usually when they sell em. Your gonna have some sway. We rent em on the road often
Mike
Discussion Starter · #11 ·
That's the thing though. I've spent a ton of time in these things over the years, but they were always rentals, and generally not rented by me. If it didn't work, call the rental company and they'll fix it right on the spot or bring one out and retrieve the broken one.
This is new territory for me.
Everything that has been advised above. Along with an issue I have seen, is a scissorlift that was victim to lots of rain and it messed up the wiring and electrical controls.
1 - 14 of 14 Posts
