1 - 3 of 3 Posts
For new construction, is there any way around sanding after applying primer with a sprayer? Heard it different ways but the sanding is to remove the 'hairs' or textured that is raised in priming. This would be with latex primer. What are the options out there? Thanks in advance.
I have found in my years of both woodworking and home repairs that a good finish will make or break any job/project. There is simply no quick and easy way to a quality finish. Sanding and prep. is key to a nice finish. If you want to cut corners, in the end it will show.
1 - 3 of 3 Posts
