Rusting frames in storefront windows
1K views 24 replies 14 participants last post by  sean2025
I replaced some floor tile at a large office complex and now they want me to tackle a very large job and I need some advice. There are 12 buildings, each with 4 to 6 units. All the doors are steel framed with windows on each side.
Most of them are rusting and they want me to strip the rust and repaint. It wouldn't be a big deal except there are small spots here and there that have completely rusted through. The largest hole I found was about 1/8" x 1".
I'm thinking about stripping off the rust and paint in the effected areas and using Bondo to fill the holes and cracks. I don't have much experience with Bondo, and I'd love to find something to do the job that's easier to work with.
Any ideas or comments?
Any help is greatly appreciated. Thanks.
#2 ·
I wish I had some more productive input but all rust needs to be removed for it not to reappear.
Any and all rust auto-oxidises. If it is present it will spread on its own. It's still in an ambient environment, oxygen and water to an extent. When you see after being painted its coming from under the paint mostly. Not a result of surface treatment breaking down from weather etc.
Maybe someone has some other input or from the www. Just trying to help you be prepared.
#9 ·
I'm thinking a flapper disk and / or random orbital sander to remove the rust on the easy to reach spots. Any suggestions on how to work on the inside corners?
I did explain to the customer that there was a whole lot of prep involved before the priming / painting could begin. I've already done three small $150 to $375 jobs for this guy and each time he's tipped me $100. He says the tips were because he's very happy with my work and professionalism compared to other maintenance people he's used in the past.
I'm not going to bid this job because there's no way to tell how many holes and cracks I'll have to fill. I believe he trusts me enough at this point to do the job on a cost plus basis. I think cost is secondary to quality at this complex. I just want to figure out the easiest way to remove the rust and fill the cracks.
#10 · (Edited)
Multi tool with sanding head.
Velcro triangle paper 36 grit and up
3x18 belt sander and pad sander for more open areas.
Cheap lathe wood turning set, flats, rounds.
Really scrape into the corners.
Grinder to keep them sharp.
Can use the lathe tools with sand paper wrapped around for odd shapes.
There are multi tool odd shaped heads with sand paper but this maybe too much for them.
#13 ·
Lots of good ideas here. I’ll add that the multi tool sanding head works great for corners but I always turn the speed down a bit, it seems like it keeps the paint from melting onto the pad and gumming it up and the corners of the paper and pad last way longer. Also having extra pads handy is a good idea, the edges wear surprisingly fast.
Another thought, I just started using some of these pads on an angle grinder to clean some rust on my truck and they were surprisingly effective, I don’t know how they’d handled painted surfaces though. I think Wagner has a paint stripping tool with a similar pad.
#18 ·
I've used this type of pad before and seem to remember it working very well, but wearing down kind of fast. I tested a spot using a flapper wheel on my grinder and it worked pretty well. I'll do a side by side comparison and see which works best and lasts the longest.
#14 ·
I had an old snowmobile and it started getting really rusty on the front skis, I used a rotary drill and a wire brush and then painted them with por 15, it turned the rust back into steel, and it looked beautiful for at least five years than I sold it.
It’s also UV sensitive so you would have to paint over it.
#17 ·
Thanks. I've never heard of that product. Unfortunately I can't seem to find it in any color other than black and these frames are very light colored so it may take too many coats to cover the black. I'll run an experiment.
#22 ·
What your seeing is surface rust which can be cleaned up and repainted sure. But what your not seeing is the rust and rot on the back side of the frames which can only be fixed by replacement!! I have a gc who routinely stores the new frames outside and uncovered for months until needed. You can't fix this amount of blatant stupidity.
#25 ·
For small rust-through spots like you described, grind/strip the rust back to clean metal, treat it with a rust converter, then fill with an epoxy metal filler (like JB Weld or PC-7) instead of Bondo. Epoxy fillers bond stronger to steel, are easier to sand/shape, and hold up much better outdoors. After curing, sand smooth, prime with a rust-inhibiting metal primer, and finish with exterior-grade paint.
