Running CAT5 over stucco
7K views 40 replies 14 participants last post by  Joe Fairplay
I need to run a pair of CAT5 cables along a 30' stucco wall. They have had these plugs to use with cable clips in the UK for years but I can't find them in the US.
Has anyone got a source here in the US?
#8 ·
That is NOT what I'm looking for! As I stated i my OP i'm looking for "nail plugs". Here's another image:
#9 ·
R U Retarded?
Try searching for "mollies" or "drywall anchors" or "masonry anchors" or "wall anchors".
They come in dozens of shapes and sizes.
It is obvious how you went from an empire controlling half the globe to an insignificant tiny island in the Arctic Circle.
#10 ·
You accuse me of being retarded when you post a product/image that is not even close to what I'm looking for let alone usable with cable clips.
Re-read the OP and my subsequent replies. If, after that, you are still unable to understand what I'm looking for then stop replying and making yourself look sillier than you already are.
#16 ·
Not they aren't. Read the description. It says;
The pin plug provides the ideal fixing in situations, where the substrate is too hard to take a masonry nail or cable clip.
Drill a 5.5mm hole and tap in the pin plug.
For fixing cable clips into soft aercrete blocks.
Its a standard masonry anchor. The package even comes with a masonry bit to install them.
#18 ·
Well, after looking at the OP, it seems Joe may be correct. Simple masonry anchors at fist glance. Though he may be a bit overzealous in his communication...
OP, is there something special about the ones you posted. Harder or softer materials? I don't see why a small screw anchor wouldn't work with a nail? Just never used them that way.
#31 ·
#40 ·
I've never seen those, great idea though. There is something I know of that might work, but I'm not sure they make them in a small enough size for cable clip nails. Look for Expandet Screw Anchors.
Or, they make cable clips with attached screws rather than nails, in which case any screw anchor would work. I have used pieces of small diameter wooden dowels for thing like this before, but since this is exterior, probably no bueno.
